This command adds an IS-IS area address to the specified routing process.
| area_name | Specifies the area name of the IS-IS process to which to add the area address. |
| area_address | Specifies an IS-IS area address to add to the IS-IS process. The area address can be from 1 to 13 bytes long and must be entered in the following format: 0101.0102.0103.0104.0105.0106.07. |
None.
The IS-IS area address defines an L1 or L2 area within an AS. An IS-IS routing process must be assigned at least one area address before it can send or process PDUs. The area address must be configured appropriately. Level 1 routers only form adjacencies with other level 1 routers with at least one area address in common. Multiple area addresses may be configured, which may be desirable during a topological transition. The maximum number of area addresses that can be configured is 3.
The following command assigns area address 0011.03 to areax:
configure isis area areax add area-address 0011.03
This command is available on platforms with a Premier license as described in the Switch Engine v33.1.1 Licensing Guide document.
